It seems that some people are having issues trying to render Skatter setups with V-Ray 3.6.
I can’t reproduce this myself, sadly.
The thread in Skatter’s forums : http://forums.getskatter.com/t/v-ray…er-objects/863
Yes, it doesn’t work unfortunately. MacOS high Sierra, SU 2017 and 2018 Pro. No luck. If I create a vrmesh of the object it works though. It is a workaround for now.
If you need more info let me know.
Best,
Peter
I have exactly the same issue.
It seems 3.6 breaks compatibility with Skatter. We will address this in 3.60.02. As a temporary workaround, open the ruby console and copy and paste the following one liner
class VRay::LiveScene::Mesh;def material;get_material(nil);end;end
This has to be done once for each SketchUp session
Sorry for the inconvenience
Thank you! That worked.
Best,
Peter
Skatter now automates the workaround in version 1.4.4 : http://forums.getskatter.com/t/release-1-4-4/967
It targets V-Ray 3.60.01 only, so it will have no effect on past and future versions.
Thank you!
