Sketch up camera Field of view + image size
:sketchup:
Hey guys,
Is there a way to save the scene field of view + image size/output? or do I have to sync between sketch up viewport/scene and Enscape?
Also would be great if I can update the scene from directly from Enscape.
cheers
In The Visual Settings it is saved.. In Main tab is Field of View and in Output tab image size.. The field of view is overriden if Synchronise Views is On but it is saved per preset.. Note that sKetchup is using Vertical FoV and ENS Horisontal FoV.
It is possible to add the scene from inside of Rendered view.. from Enscape.. I never tried updating
Edit
If You go to View Management select a scene, click edit icon on the right, do the changes that You desire, click Save at the bottom..
