I’m having an annoying issue I’ve yet to discover the solution to. When batch rendering several views, with several passes like light mix or back to beauty you can quickly end up with a lot of files. All batch rendered images are saved into one single folder. Which is a bit annoying to be honest.
Unless I’ve missed the setting can you not save scenes when batching rendering to their own folder? All passes etc are saved into a folder relating to each scene.
