Sketchup 2026
Just wondering when we can expect a SketchUp 2026-compatible version of Enscape?
Hi @The_Guru , SketchUp 2026 is already supported in our two latest preview versions (see our recent 4.13.0 Preview 1 post here).
The next official release, expected around the end of this month, should also include full SketchUp 2026 support. If you’re unable to use the latest preview(s) at the moment, especially if you’re in the middle of an important project and need to produce renderings, then this upcoming release should cover you.
Once our next full release has been published (or once official support has been added to a release, generally), I’ll also make sure to inform you via this thread once more.
Hi! The new 4.13.0 Preview 1 doesn’t want to load on Sketchup models I have with multiple existing scenes- it just gets stuck saying ‘Loading Scene data…’. Is this a known issue and is there a bug fix coming soon?
Hi @Tamalpais , and a dear welcome to our forum.
We’d be glad to investigate the cause behind this further, especially since this occurs within our latest preview. Could you, therefore, kindly forward this behavior to our official support team directly as detailed here (ideally making use of the support button itself)? This way, we’ll be able to troubleshoot the exact cause behind this further and get back in touch with you afterwards.
Thank you very much in advance.
