Sketchup and Vray
Hi All
i start by pointing out that i am a noob in vray and sketchup. I stumble upon Grant Warwick Mastering Vray videos. and have a question (i know he is using MAX and older vray)
i just wonder how one could recreate in vray 3.4 Curves like he does for materials reflection. i could use Falloff Map in a reflection channel but i do see such thing as Curves to adjust am i right?
Thanks for any update about that one
MM
The curve editor is part of the 3ds max native Falloff map.
The Falloff map in V-Ray for SketchUp comes with a redesigned UI in v3.6. You can fine-tune it using the color sliders and falloff mode parameters.
Adding curve editors to our textures is something the dev team will explore in the next major release.
Kind regards,
Peter
Thank you Sir for you replay! Appreciate a lot!
