just want to know if there’s a way of getting the coordinates of the SU camera.
Thank you all
Thank you all
Re: SketchUp camera position
Sketchup.active_model.active_view.camera.eye
Do you know in which unit are the coordinates?
I got this: Point3d(4599.76, 998.761, 1157.9)
Changing the model units doesn’t affect the values, then it must be some program standard.
Also, is it possible to get the Rotation in X, Y, Z too?
I want to animate in an external app.
Found this: http://code.google.com/intl/pt-BR/apis/sketchup/docs/ourdoc/camera.html
Inches. SU always uses inches internally - regardless of model units.
Check the Sketchup Ruby API for full set of methods available:
The Sketchucation’s Ruby forum is a good place to look around if you do any SU Ruby work.
