Sketchup linked model into Revit not exporting in Enscape as desired.
Hi All. Wondering if someone can assist.
I have a Revit model(s) that I am trying to export and some of the Materials that come from a linked Sketchup model (surroundng building context) is not exporting as expected.
It seems linked to when the Revit Graphic display is set to ‘Realistic’ that the Sketchup model doesnt display as it might appear in Revit at the ‘Consistent Colours’ setting.
e.g. the canal in the image below would be blue.
Has anyone else come across this and can offer advice on how to get Enscape to export to the Revit '‘Consistent Colours’ setting ?
thanks, Dan
Please switch between the Material Selection (Appearance / Graphics) and you might find linked files will refresh and show the desired material state.
thanks Phil. Found it in Revit under Object Styles of Sketchup model. Can then manipulate Layers/Materials of the imported Sketchup model thru this, and pulls thru to Revit and ultimately Enscape renders. All good now !
enscape result.
how do you link a model from sketchup to revit???
