Why My SketchUp Model Doesn’t show ? Some of the object missing
Hi @Muh_Nur_Alam , welcome to our Forum.
In the first instance please ensure that your system meets our requirements detailed here: https://learn.enscape3d.com/blog/knowledgebase/system-requirements/
If that is the case you can make sure to update your graphics card drivers, if the dedicated GPU inside of your machine is supported.
Should that not do the trick you can also try to check if the model is not located too far off of SketchUp’s initial project center location which can sometimes lead to problems as well.
In case the above doesn’t help please simply forward this to our dedicated support team via a support report as detailed here and we’ll be able to troubleshoot this further. Thanks a lot in advance.
