Is it possible to get SketchUp texts and dimensions visible in Enscape?
(made by “text and dimension tool”, not by “3d text tool”)
@InDe , that is currently not possible and would have to be added via post-process. You may consider overlaying an Enscape rendering over the SketchUp layout(viewport) or blending the two together for example as an alternative perhaps. I will forward your inquiry accordingly but this may technically not be feasible.
@Demian Gutberlet
would be cool if that could work!
other question how hard would it be, to make a checkbox to texture in the custom asset area the proxy geo?
because the dimensions are used often to send the client as well and then the goods are all white and dull in a way.
greetz natnat
