SketchUp to 3ds Max Workflow with V-ray
I create all of my models in SketchUp and then import the SKP files into 3ds Max for rendering. When imported, all materials are converted into Physical Materials in Max. I currently have to manually override these, replacing them with V-Ray materials and reassigning the correct diffuse maps.
Does anyone else work with a similar workflow? Or know of a suitable way to avoid having to redo all of the texturing in 3ds Max?
Many thanks.
Use the V-Ray converter to automate the process instead.
Hi Aleksandar,
When I do this, the colours of the textures and maps end up being much lighter and washed out than they should be. Is there a way to correct this?
Is there a difference if you switch the color management mode (Rendering > Color Management) to Legacy Gamma workflow?
Please see the attached images that I have tried to name logically as to what they are.
1. Physical Mat Converted to V-ray in max
2. Manually added bitmaps and allocated to diffuse slot of a v-ray material
3.Legacy gamma 2.2 of the Physical Mat Converted to V-ray in max
Mind if you attach that scene (prior to converting)? Also, make sure the Rendering RGB primaries (Render Setup > Settings > Color management) is also set to sRGB when using Gamma workflow.
Hi Aleksandar, I have just sent you a message with the zip file attached. Thanks
I think the main issue is a known one: when converting Physical Materials, the reflection IOR is transferred to VRay’s IOR directly; however, by default, the VRay Reflection IOR value is locked to the Refraction IOR (which is not changed), so the result is not identical. I’ve recently logged it for dev investigation (VMAX-15402).
Can you confirm if it’s the same thing by changing the VRay’s refraction IOR (after conversion) to 1.52, too?
Thanks! I have a few more small issues surrounding this. I have sent a message. Cheers
after i import my sketchup file and run vray scene converter, i just paste the line below into the script listener in the lower left corner. It turns all my white reflection colors to black so i’m at least back to normal looking and then adjust reflection as needed.
for m in (getclassinstances vraymtl) where (m.reflection_glossiness == 0.0 and m.texmap_reflectionGlossiness == undefined) do (m.reflection=black)
@Neil_FD you need:
and enable aces instead of gamma
