jstrob
August 5, 2016, 3:31am
245
We need 2d displacement to work with UDIM to do GREAT displacement.. I found Vlado that the 3d displacement I don’t feel any autobump, since it’s still way less precise then 2d displace.. is there a parameter to tweak to make the autobump crisper? Can you put a guy to make it work with UDIM like in Maya that 2d displace? I need it for hyper realistic character… we need super crisp 2d displacement..
EDIT : Also Valdo, does Alsurface have a IDraytrace to make it in the same set like the sss2 and skin shader ? Does it work the same?
Ca I ask you what do you mean by autobump? And what’s the advantage of udim for displacement? Isn’t it just another way of numbering the UV tiles? I guess you are using Mari?
For me it seems that this workflow gives pretty crisp results at least from zbrush with 3D displacement: Accurate Displacement Workflow | Akin Bilgic
