Sky box scaling
When using a skybox, they seem to scale incorrectly. I have tried this with several sky boxes, and several revit projects.
I do not see any settings within Enscape to change this, and I’ve tried modifying every setting in Revit I could think of that would affect this.
So far I understand you run in a general problem independent from Enscape - the scale of a HDRI panorama environment is fixed during shooting the pano. Only you can change the field of view (lens length). Best you set your virtual camera at the same position like the real world camera was during the shot. In your case, the camera was approx. 1m above the ground. If you need a birds view than you need to look for a drone shot panorama.
Thanks @Micha , I’ll look for skyboxes taken from a higher vantage point. I wish there was a virtual way to elevate your eye hieght after creating the skybox “room.” But maybe that would distort the image too much?
It wouldn’t work, since the perspective lines are fixed in the photo, I will be looking wrong. Only it works a little bit for captures of large places like a shot in the desert. There you could move the horizon a little bit up and down.
Exactly. You could distort it but that would not work well. You can not move in your skybox anymore because it is just an image. No geometry information behind. The assumption is, that everything is infinitely far away. For close things to the camera, this is increasingly wrong and only looks good from one perspective.
