setup is c4d r19 & r18 and corona last release candidate (release candidate 4 )
I use normal sky obj with light material (HDRI) and if I delete or change the HDRI map the viewport don’t updated (if I deleted the sky obj, in the viewport still HDRI appears)
But the strangest thing the object (cube for example) is affected by the Hdri update…
Is anyone experiencing a similar phenomenon?
Not that I’m aware of, can you share a screen recording of said anomalies or your scene?
Does Sky stay after you restart IR?
Am witnessing constant erratic behavior with IR lately and this also happens among other things (+ shadow catcher turning black & objects disappearing, just because of simple changes as is phong tag angle, object soloing, editor visibility…), but at least IR baboon doesn’t crash or attack… hahaha ![]()
Edit
Also, just found out HDRI textures applied to Sky objects are reverted (mirrored) on X axis (FIX: set X scale to -1).
After rotating Sky object, shadow catcher keeps the projection from the camera. This can be observed only in active camera view. In viewport view (out-of-camera) shadow catcher shows as it should (is correct).
how I can restart the IR?
The bugs are fixed in the following version?
To restart IR, either:
A. Simply, Close IR window & Start/Open another one,
or
B. On CFB top bar menu:
- Click Stop
- Click & Hold Render (submenu opens) > move cursor to Start IR & Release
The problem has not been solved, in my opinion it’s a software bug
I think it’s best to send us your scene to check. The private uploader is in my signature below ![]()
Successfully uploaded as 1541098012_testcorona.c4d. Now please post the filename into your bug report thread.
I hope you can see it ![]()
i have 2 hdri img in my scene the I cant upload this in Private Uploader so just take any HDRI you have on computer
testcorona.c4d (849 KB)
HDR008.hdr (6.05 MB)
HDR009.hdr (6.17 MB)
Thanks for the files, we’ll take a look. Also, on the uploader page there is a link at the bottom for files up to 10gb. ![]()
Nothing odd happening for me, unfortunately. The only thing I noticed in the scene is that you aren’t applying your HDRI’s to a Corona light material. Apart from that, when I delete the sky it deletes…
Strange..I try to delete the Cinema and install again Maybe it will help
I’m not sure that would help but no harm in trying. I would also suggest installing our latest release B2 final from here: Download | My Chaos
At the end of the reinstallation was not helpful, at the end it turns out that the problem was in the project’s TEX folder I deleted it and created a new one and the problem was resolved
thanks for support.
Hi, glad to hear you figured it out! Thanks for letting us know.
