I loaded a night Skybox in my Rhino scene but it shows the skybox very bright, as if the scene is set to daytime and I don’t know where to change this to get a night scene?
Also I can’t change the Radius and the Intensity of my Lights (Pointlight) is this just not possible at the moment, or did I miss something?
every color besides black in a skybox will light up your scene. You can control the brightness of your skybox in the Enscape settings in our latest preview version:
I downloadet the update and now the Skybox problem is solved.
Yes exactly, I change Intensity of the pointlight but it stays the same brightness in Enscape. The intensity only changes as I change the daylight, means, when it’s night the pointlight is very strong and all white, when I change the day time to sunset, then the point light is softer and not so strong, but also then I cannot control it with Rhino settings.
Can you please send us your test file with the cubes and use the feedback button so that we know your system specs. Do you use any other plugins for managing your lights?
That was it! I was trying to manage the lights with the vray settings and didn’t realise it.. a real beginners mistake.. I changed the renderer to rhino and now it works, of course.
