Skybox Reflections Bug ?
Skybox reflections on the left shows it’s daytime
Using enscape 2.2.1.11
Rx 480 8GB with latest AMD drivers
This looks like a bug. Thanks. We will investigate.
We’re not able to reproduce that bug, even on AMD machines. Can you please give us some details on how you achieve that behavior?
I assume you have a skybox loaded. Does it happen on all surfaces? I looks like it also occurs on the reflection at the wooden table? Does it the brightness change when you change the time of day or is it constantly too bright? Is it related to the skybox brightness slider?
Thank you!
the skybox is construction site with default settings
the time in the scene is 18:25
there is a small difference on that time in reflections 18:15 to 18:25, when i go beyond 18:30 then it is fine and gives accurate reflections.
you can see here all default settings
at 18:25 its like daytime and at 18:30 its night
Thanks a lot for your efforts! Now its clear what caused this bug. We will fix it soon. Thanks :slight_smile:
Fixed in 2.2.2.1
Wunderbar
