skymap on glass
Can anyone recommend a quick and easy way without changing many settings to get a sky map to show up as a reflection on glass (without using photoshop of course)?
I have been trying for sometime and it seems the options are endless. Is there a quick way?thanks
Re: skymap on glass
By skymaps, I think you are refering to BackGrounds/BillBoards:
Check out this thread
http://asgvis.com/index.php?option=com_smf&Itemid=90&topic=4059.msg20669#msg20669
or, more simply, you just insert a sky bitmap (jpg or hdr) in the ‘environment’-background slot and set the UVW to ‘environment’
David
Re: skymap on glass
thanks David,
i feel like i have tried that already but will try again using the the more detailed thread you posted earlier.
