Slaves do not join render
I’m having a persistent issue with my slave machine not joining in on the render. I don’t get any errors in the V-Ray messages, but the slaves never engage. The message I do see is, “Scene loaded. starting render”, but nothing ever happens. Small test scenes work fine, but anything with any meat doesn’t. I’m running 3DS MAX 2013, and V-Ray 2.00.01. I starting having this issue when I upgraded MAX from 2012 to 2103, and when I upgraded V-Ray to the latest build for MAX 2013. I’m running the VRay Spawner as a service, all firewalls are turned off, and I’m an admin on all machines.
HELP!!!
Here is the last part of my log
[58515,59618,-46.995]-[58727.7,59818.5,279.421]
[2012/A/7|22:32:10] Bounding box for “iTrees-02-Elm_005” is [58429.5,59719.1,-46.995]-[58610.5,59925.9,279.421]
[2012/A/7|22:32:12] Bounding box for “iTrees-02-Willow_01” is [58386,59881.8,-61.9837]-[58638.9,60092.7,242.25]
[2012/A/7|22:32:12] Bounding box for “iTrees-02-Elm_04” is [58233.4,60323,-46.995]-[58414.4,60529.8,279.421]
[2012/A/7|22:32:12] Sampling displacement maps.
[2012/A/7|22:32:12] Setting up 8 thread(s)
[2012/A/7|22:32:13] Threads completed
[2012/A/7|22:32:13] Setting up 8 thread(s)
[2012/A/7|22:32:14] Threads completed
[2012/A/7|22:32:14] Setting up 8 thread(s)
[2012/A/7|22:32:19] Threads completed
[2012/A/7|22:32:20] Setting up 8 thread(s)
[2012/A/7|22:32:24] Threads completed
[2012/A/7|22:32:25] Updating render lights
[2012/A/7|22:32:25] Setting up 8 thread(s)
[2012/A/7|22:32:26] Threads completed
[2012/A/7|22:32:26] Updating atmospheric effects.
[2012/A/7|22:32:26] Updating render effects.
[2012/A/7|22:32:26] Scene setup: 20.7 s
[2012/A/7|22:32:26] Compiling render instances geometry.
[2012/A/7|22:32:27] Compiling lights geometry.
[2012/A/7|22:32:27] Preparing ray server.
[2012/A/7|22:32:27] Creating and initializing 8 thread(s).
[2012/A/7|22:32:27] Allocating memory for build data of 2748461 faces (21987688 bytes, 21.0 MB).
[2012/A/7|22:32:27] Initializing face build data.
[2012/A/7|22:32:28] Creating ‘done’ event.
[2012/A/7|22:32:28] Starting first thread.
[2012/A/7|22:32:28] Waiting for thread completion.
[2012/A/7|22:32:28] Releasing thread resources.
[2012/A/7|22:32:28] SDTree statistics:
[2012/A/7|22:32:28] Total number of faces stored: 2748461
[2012/A/7|22:32:28] Max tree depth: 55
[2012/A/7|22:32:28] Average tree depth: 26.6288
[2012/A/7|22:32:28] Number of tree nodes: 1272065
[2012/A/7|22:32:28] Number of tree faces: 10520461
[2012/A/7|22:32:28] Number of tree leafs: 551581
[2012/A/7|22:32:28] Average faces/leaf: 19.0733
[2012/A/7|22:32:28] Memory usage: 289.32 MB
[2012/A/7|22:32:28] Scene bounding box is [57761,58586.8,-216.01]-[60547.6,63229.5,2185.82]
[2012/A/7|22:32:28] Preparing direct light manager.
[2012/A/7|22:32:28] Initializing built-in VFB.
[2012/A/7|22:32:29] Preparing global light manager.
[2012/A/7|22:32:29] Irradiance sample size is 84 bytes
[2012/A/7|22:32:29] Broadcasting NOTIFY_PRE_RENDERFRAME.
[2012/A/7|22:32:29] beginFrame() done.
[2012/A/7|22:32:29] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
[2012/A/7|22:32:29] Setting up DoneCallback.
[2012/A/7|22:32:29] Rendering frame region (0,0)-(5120,3840).
[2012/A/7|22:32:29] Photon size is 56 bytes.
[2012/A/7|22:32:29] Light cache sample size is 120 bytes.
[2012/A/7|22:32:29] Building light cache.
[2012/A/7|22:32:29] Tracing 751689 image samples for light cache in 8 passes.
[2012/A/7|22:32:29] Setting up 8 thread(s)
[2012/A/7|22:32:29] Light cache time interval is (0.000000, 100.000000)
[2012/A/7|22:35:41] Threads completed
[2012/A/7|22:35:41] Merging light cache passes.
[2012/A/7|22:35:49] Light cache contains 197444 samples.
[2012/A/7|22:35:49] Light cache samples collected; compiling lookup tree.
[2012/A/7|22:35:49] Prefiltering light cache.
[2012/A/7|22:35:51] Rendering image.
[2012/A/7|22:35:51] Setting up 8 thread(s)
[2012/A/7|23:52:18] Render host 192.168.8.173 added
[2012/A/7|23:52:26] Scene transferred to xp64rend4
[2012/A/7|23:52:47] Server 192.168.8.173: Scene loaded; starting render.
[2012/A/7|23:52:47] Server 192.168.8.173: Starting frame 0.
[2012/A/8|08:23:18] Render host 192.168.8.158 added
[2012/A/8|08:23:24] Scene transferred to xp64rend1
[2012/A/8|08:23:40] Server 192.168.8.158: Scene loaded; starting render.
[2012/A/8|08:23:40] Server 192.168.8.158: Starting frame 0.
here is a report on my dongle: I’m currently in a render, and it’s showing all the DR licenses available, which is true. Although I’m rendering the job, with all nodes assigned, they are not engaging.
V-Ray/Adv (1.5/2.0)
Total
Engaged
Free
Render licenses
1 / 1
0 / 1
0 / 0
Interface licenses
1 / 1
0 / 1
0 / 0
DR licenses
10 / 10
0 / 5
5 / 5
Could you please confirm whether you have identical V-Ray versions on all of the machines?
They are all running 2.30.01 - I am assuming that this is the latest.
Yes, that is the latest official build.
Is this the same issue as this one:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?69522-DR-will-not-work-with-high-resolution/page2
Yes. one in the same. I shouldn’t have started another thread.
