Slider range of dir lights
… could be set so that 1 is at the middle position of the slider, because this light type is without decay and the typical needed range is from 0.1 … 10. For example at the moment it’s difficult to set a value like 0.7 per slider.
Best-
Micha
Hello, @Micha ,
Thank you for your feedback. I logged an improvement suggestion for increasing the default slider range so that 1 is the mid value, which will allow setting values greater than 1 with the slider.
Kind regards,
Iva
