I just bought new GTX 1080 from Gigabyte and without any problem overclock it to 2GHz with still some gap. So I wanna test it in VRay RT. But this is what I get - its slow, noisy and slow. Like GTX 780 I had previously or maybe worse. Look at pictures - one from CPU (5960X @ 4.2GHz) and GPU (this GTX 1080), both after 3 minutes of rendering (both BF+LC). Why GPU looks so terrible?
And VRay said using all GPUs (I have only one with two monitors pluged in), but when I try to select OpenCL devices, it said this:
I look at sensors of GPU and it really run at 2GHz with 100% load. But I think its strange.
And one more big problem: I render using VRay RT and it works. After a minute I wanna render it again and it doesnt work, it doesnt make sense. This is what I get. But its absolutelly useless I cant work with this.
Are you using the same gi engines for both ? LC is enabled for RT as production only (since in active shade it doesn’t make sense).
Also, if you have many gpus try increasing rays per pixel / Ray bundle size to something like 96/256.
It might be easier to just send the scene over so we could take a look.
Best,
Blago.
As I said, LC is enabled for RT only if RT as set as production. If you use it in Active Shade it will be BF/BF.
If you send the scene over it would help a lot to find what the issue is.
About LC, I know about that, but problem is somewhere else. I can send you a scene. You will see if its slow and noisy or what. But the errors I got after few renderings I get with every scene, doesnt matter what I render.
Does it happen even with scene with a sphere and a light ?
If yes, then most likely it is something related with the setup. In that case You should either provide more details about V-Ray version, drivers version, hardware, etc or we can arrange an online session with our support team, so we can investigate.
Would it be possible to send us another mail to support@chaosgroup.com ? I just checked and didn’t find any mails received from jiri.matys@gmail.com this week. Or maybe you are using another email address for this support request?
It would be great to have the scene file until we arrange a remote session and troubleshoot the rendering crash during Active shade sessions. So please send us the download link again to open new support ticket in our system and we will provide you with more details about the remote access procedure.
Thank you.
