In your material setup, do you use any baked shaders? Also, does this slowdown happen with all materials in the scene or just some in particular? Would you mind sending us this scene so we can investigate it? Thank you.
Hi @aleksandar.kasabov thanks for your prompt answer
the images are simple JPGs with very low res… so no baked images.
I can’t remember if happen with other materials but i can send you the scene
I’ll send you via messanger?
thanks
best
nuno
it’s not 100% related, but I unfortunately experience the same issue (even worse) when I open scenes with Vray 3.70.05. The opening of a normal complex project takes about 1h. After that, work is almost impossible because the material feedback is extreme slow and the computer almost freezes. Maybe it has something to do with the Rysen 3990X because on my older System a dual Xeon there are no problems of that kind.
Can you plz tell me how to disable the material previews? Then I could render with this machine at least.
Hi @H_923874 sorry to ear about that … we run also on Rysen 3990 machines but also hapen on Intel I9… not the scene converter situation but the material slow preview…
to disable the material preview go here (image bellow)
hope this can be fixed…
best
Hi people,
I just wanted to report that in the meantime, I did a full “format c” - reinstallation of one of our workstations and then had only Win 10, Cinema 4d R23, Vray 5.20.02 and the necessary most recent drivers installed. Just to be sure, that the material preview lags are not somehow software-related on our side. Unfortunately, still with this minimum-system, the issue stays the same. We are running only AMD machines (in this case a Threadripper 1950X) so I cannot test, whether the problem might be AMD-related, but if I understood @nunomatos correctly, it also happens on Intel systems.
Are there any further thoughts/investigations on that matter at this point? Because it is the main reason for us to stay away from Vray 5 for production at the moment.
What seems most strange to me, is that only a relatively small group of users seem to have this problem.
Our developers made some further investigations and it turned out that a major issue with the material previews has been overlooked after some optimizations. We are currently working on a fix which will be available as soon as possible. I will let you know once the fix is available. Thank you.
Recently our developers made some changes that should affect the material preview. The changes are in the latest stable builds which you can find here.
Could you please download and install the latest stable build and see if you will experience faster material previews. Thank you.
Hi all
first apologies for the late answer
in fact after the last update, all the things become more smoth, even with large images, so thank you Chaos Team
but what really makes the difference (and this tip, thanks to @stefan Laub) is, first have always absolute textures path when pushing a texture and second is turn off the paths in C4D preferences. Apparently even you have the textures in the project folder, C4D still searching in the paths you have in preferences… I can make a small video, although this is now much faster with this last update
the only stepback is that when you have textures without absolute path, C4D will try to search and if you don’t have any path in C4D preferences, C4D will not find…
how can you work with absolute paths? … projects would have to be at the same place all the time, if not they break… this is not really an option.
@nunomatos : which c4d version do you use? newer ones have an indexing system for assets i think…
@index we use dropbox so we have all the paths the same… don’t know how to work on server but i think you can virtualize the same path (i’m not pro on windows
we still using R23 because we don’t have yet some plugins working on R25 … but i heard that yes… R24 and new have a better system… in any case is really stupid that C4D needs to “search” on paths we put in c4d preferences…
unfortunately, we still experience huge problems with the preview speed of classic vray materials using C4D R23 and Vray 5.20.06 (the problem persists with C4D 26 and Vray6 beta).
I also tried what @nunomatos suggested (absolute texture paths and no search path) but this did not help in our case. I feel that the previews are not really faster than in Vray 5.10.24 when I originally encountered the problem.
Simple scenes with few materials are ok to work with, but when adding more materials to a scene, the previews take longer and longer to render and block the responsiveness of C4D increasingly.
I am working on a scene with 200+ materials, some use high-res textures but most are pretty basic.
However, node materials in the same scene preview fast and fluent and do not block Cinema4d, as I would expect it.
I would like to report that we experianced similar issues recently both with the standard vray material and the node materials. After a while the node materials became really slow to update.
I noticed that parallel to this when I’m searching for a node in the node editor its loading really slow. for example when i typ in “color” it takes a good few seconds to show me the color noder. I Don’t know if this is a maxon issue or a vray issue though…
