Hi
I’ve just installed the trial to give Vray a go, but I’ve found that reloading linked files in Revit now takes several minutes instead of seconds, is this something that people have come across and is there a fix? I will have to uninstall Vray if there isn’t an easy fix as I cant afford the increase in time that this will cause as most of my models are built up from many linked files that are regularly changed and reloaded.
Thanks!
Hi @ddybyapepper ,
Thank you for reporting this issue. We will have to test it in our environment.
Are you able to provide the project for testing purposes?
Best,
Ana
Hi @ddybyapepper ,
If you are not able to share your project with us for some reason, please advise at least on the following questions so we can replicate it:
- Which version of Revit you are using?
- What is the size of your main project and the size of the linked project you are reloading?
- How many instances you have of your linked project that is being reloaded?
- Is the V-Ray license acquired when you face this performance issue?
- Is there a running V-Ray renderer while you reload the linked project?
Thanks,
Tanya
V-Ray for Revit Team
Hi @ddybyapepper ,
The new V-Ray 3.7 for Revit is out. Please give it a chance and advise if you still face the same problem with links reload.
Cheers,
Tanya
