Small bug - Camera Tag copy
Hi
Just small bad behavior. If I copy Corona camera tag from one scene camera to another ( without tag of course ) the camera tag settings are reset to defaults. For example I set camera setting to ISO 400 ( from default 200 ), shutter to 500 ( from default 30 ) and aperture to 11 ( from 16 default ) and copy this modified tag with ctrl key to another camera in the scene the shutter speed settings are reset to default 1/30. Iso and aperture works fine and during the copy operation keep on as the modified value.
Corona A6
Cinema R18
Quite sunny weather outside and good music in my CD player :smiley:
Regards
Neb
This is by design. Values that are present in the camera itself are not overridden by the tag. Instead, they are mirrored from the camera object. This is why the tag shows different values when placed under different camera objects.
