Small kitchen
Hi everyone, this is my last work. Modeling took 1h, render settings and rendering took 2 hour. 3 hours in total. Coments are welcome.
Uploaded with ImageShack.us
Re: Small kitchen
wow you did the job pretty fast and the result was good. Probably adding some reflections on your marble texture and the lamp would help a little bit. I like your fridge´s texture, what settings did you use?.
Re: Small kitchen
That’s a pretty technical illustration of a kitchen right there. I mean, I recognize some elements that I use when I build furniture/ kitchens.
Be aware of that counter corner, that require “edging”. It will look weird, trust me. It’s about the radius and the round edge of the counter. The rendering it’s amazing, for the time you spend.
Good work!
Re: Small kitchen
Very realistic
Re: Small kitchen
Rodrigo Nunez. Thanks, the marble texture has reflection, but it has nothing to reflect, so it looks like there is no reflection(my fault). What about fridge texture, it is very simple: default texture with white color and reflection. Highlight and glossness relfection is about 0,95 :slight_smile:
Remerber that for textures such as: mirror, glass, porcelain and etc. material quality is not very important. The most important thing is that these material must have what to reflect, in my example kitchen view.
Stefanq I am very thankful for comment. I have to admit with you, that edging looks weird, but I have an example in real with this non-professional edging. I will try to avoid this mistake in my future works :slight_smile:
Thanks for all.
Edenux
Re: Small kitchen
maybe a little more reflection on some materials, and in my opinion lightning is little flat to me, but in all is a good render.
Re: Small kitchen
Teo, thank you :slight_smile:
