small loop with interpolated glossy reflection
Been tricking with interpolated glossy reflection. The values need to be realy high. There is a bit of flickering due to the div-x codec; it´s not the interpolation!
Hope you like it :slight_smile:
/Daniel
http://www.redrival.com/roppin/liten\_s.avi
What kind of settings did you have to use to get that and how did the rendering time compare to just doing it the regular way with low subdivisions?
V Miller
did you use a pre-saved solution or calculate a solution for every frame?
I didn´t even try without interpolation. I dont know what it´s like in an animation. Allso, using subdiv together with motionblur can realy slow things down, I think. maby I try it.
sttings in the material:
subdivs: 50
min rate: -3
max rate: 0
clr tresh: 0.12
nrm tresh: 0.2
Rendertime: full pal was about 9 min/frame on 3 ghz pentium 4, 2 gig ram. I think it´s OK.
hope this help.
/Daniel
Argh, them there chairs are dancing :stuck_out_tongue:
Nice little animation. :smile:
-Matt
i hate interpol. glossy refl. in animation..they always have areas with flickering… i normly use the normal glossy refl. …
I did a test using only 16 subdivs as you proposed vance3d, and the result was OK and slightly faster at least when not so much motion in the scene.
thanks for that!
/Daniel
