Small Meeting Room
Just a little test with a light tunnel after seeing tutorials on soft lighting tutorial by @Vlad Moldovan.
Generally happy with the lighting but not too happy with the plant - the cast shadow seems off. Could this be due to number of .png images? Each leaf is separate png.
Cheers, Steve
Updated with some improvements:
Where did you get your materials from?
Which materials specifically?
The metal grid ceiling I made in Photo Shop - Think I’ve shared it before but happy to share again.
Carpet is just a download from Interface I think using albedo as bump.
Wood floor is from Poliigon.
The rest I think are pretty basic materials with a little smoothness. Table top I think I just used a sand texture as normal map to give the plastic grain.
I made some improvements to the image in the thread I posted in Showcase with the same title.
Thanks, steve.
Add some ies lights in your scene and you will improve 1000x.
also you can check in a light mode view so you can consider whether it suits your needs
…a beautiful, "simple" scene without any superfluous decoration - Good! I like the clearly maintained colour theme :thumbup:
(I would almost recommend resisting “our common” reflex to place a plant even :wink: )
