Small suggestion
Status: new
  1. Can there be an option for VRayWireColor in the rendered elements during animation rendering. This will facilitate the production of most post production personnel. 02. I want to output sequences in PNG format and also want to render individual files within the elements. But if both are needed together, PNG format will not have the option for ALPH. Can there be any improvement in the next update? thank you
Submitted on AHA Ideas by ruan bin (VANTAGE-I-172).
Hi ruan.
  1. Vantage currently supports MultiMatte and ObjectMask/MaterialMask(which is generated automatically) Can you not use those instead of a WireColor?
  2. The alpha is exported in a separate file and not baked in the main beaty image when rendering render elements intentionally. You can easily use it to mask any layer you later wish in your post production tool f.e. Photoshop. Can you explain more why would you want the alpha to be baked and not as a separate file?
Submitted on AHA Ideas.
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
