Only a few things bother me though. The lights don’t look bright enough. Your dirt bump looks good on the walls (like some coral surface) but is a little too pronounced on the ground. The environment looks good and thick but it might be a little too blue? Great work though
You see that space, dunno how to call it, “void” at the bottom?, is the only one that it has around the yellow and black painted lines, in the drawing it represents some kinda “hole” that goes deeper in the structure, while in the rendering the result so far is the opposite, we dont get that feeling of “going deep”, i think is because the light in there is wrong, the deeper part should be darker than the upper part, you got it the other way, is brighter in the deeper part and darker in the upper part.
Maybe add also some line of little lights going down, make the lights smaller (perspective will take care of that) and less brighter as youre going down, it will accentuate (typo?) the feeling.
