Smoke die on contact
Hello is there a way to make smoke die on contact with TyFlow particles (objects)?
Or a way to make an object build up from smoke?
I currently have an object that builds up from TyFlow but then the emitters turn to smoke and the object is now basically smoke, which is not quite what I want.
Maybe someone knows a tutorial in this direction or can give tips.
Thanks a lot
You could check out redefinefx.
