Smoke - Light Link Flickering
I am testing this scene. Cup blasting through snow.
The sim works fine, but there seems to be a problem with the light linking between the main light (rect, directional) and the smoke.
For some frames the light is linked, others appear dark.
https://my.green-cloud.at/index.php/s/LNkG9C87mWTYCtJ
The GI mode is already set to Brute Force / Brute Force
The problem happens inside maya VFB, as well when rendered over deadline (3 machines)
Would be glad to know if this is a known issue and hopefully a quick fix.
Martin
Recently we found and fixed a couple of issues regarding Light Linking in Volumetric render mode.
You will need to upgrade Phoenix FD (to the latest nightly) and V-Ray for Maya with the latest Release.
If after upgrading V-Ray and Phoenix the issue still persists,
you can try rendering in “Volumetric Geometry” render mode, while sending us your scene for debugging so we can find what the issue is.
Hope that helps,
Best,
Kostadin
Hello Kostadin
how do I get the latest Phoenix nightly.
through the download area I can just see Phoenix 4.00.00 for Maya 2018 Next
Very much curious if this solves our problem
Martin
Hey, make sure to check the sticky topic in this forum about nightlies :wink:
Hello Niklov
I downloaded and installed the latest Vray & Phoenix
Still the problem occurs.
Switching to Volumentric Geometry does solve the problem, but it renders slower and the look is more solid.
So I packed the scene for you here.
Data and the HDRI image included
https://my.green-cloud.at/index.php/s/PgbNJF652yxRegM
It would be great if you could take a look at the scene
Martin
btw: totaly other question. I cannot find the Vray Next Edu in the download section. Thnx
Thank you for sharing your scene!
I feel like we are talking for different Phoenix and V-Ray builds
Just to be sure here are the builds that I’m taking about:
V-Ray - Chaos
Phoenix FD - Chaos
Could you confirm that these are your builds, and if not could you give them a try?
Thank you for verifying the builds!
it is expected to have “Volumetric Geometry” render slower, as it is a bit more flexible (enabling us to achieve more advanced effects at the cost of speed).
Meanwhile we will take a look at your scene!
pretty happy with Volumetric Geo right now
thnx for your support
in “Volumetric Geometry” changing the Smoke Opacity from “Simple Smoke” to “Smoke” gives me a stable alpha in those floor connection areas.
hmm - tricky pony
Hey,
Can you double check in your Maya log after rendering if you are getting a warning that sounds like:
// Warning: V-Ray : To get better results with Volumetric Geometry mode rendering, you may need to increase the Max transparency levels of V-Ray to about 134. //
If you indeed have this, follow the advice and it should resolve the issues you are getting :slight_smile:
Cheers!
thank you Svetlin - now it all works perfectly fine
Sure, use the Render Cutter to remove geometry at render time - Phoenix for Maya
Excuse us for the delay, we’ve found and resolved issue.
If you use the latest Phoenix FD 4 nightly build Light Linking in “Volumetric” render mode should work as expected.
Cheers,
Kostadin
