Smoke with wind, more control needed
Hi guys,
I have this case where I produce smoke from volcano. What I need is just a column of a dense smoke rising up and bend after a moment.
With a standard wind space warp I cant get it, cause it is a global force which means the smoke starts bending also from the bottom of the column, not in some part of it where I would like.
Max wind doesnt have a right falloff which could be the answer.
Could there be some other way to control the smokes traveling through the air?
This could be the result I try to achieve.
you can use the mapper control over the velocity channel. set up a texture that has color (0,0,-1) in the points above some z value and apply it in the mapper
second option: cooling+negative smoke buoyancy. actually this is the real case, the smoke is heavy, but is moved by the hot gases
Thanks Ivaylo again for the quick reply.
What kind of a texture should I use in this texture option?
Cooling+negative buoyancy I already try, but still I dont know how to control the direction of the smoke after the cooling, cause the wind affects uniformly also to the bottom of the simulation
well, the easiest way is to use the standard gradient texture, but it has an issue - the mapping offset does not work, that makes the task complicated.
there are also other wind modifiers you can use that are not global. go to www.maxplugins.de and find a nice one. i assume all space warps would work with pheonix
