I’m trying to get a V-Ray repo started at work so I can start making some custom texture plugins. I’m working with Linux CentOS Linux release 7.4.1708 (Core), Maya 2018.4.P07, V-Ray Next for Maya, update 1 (v4.12.01.29159), building with rez.
I’m trying to start with a simple example, the Fresnel texture plugin, but it seems that any .so library I point to in CMakeLists.txt isn’t getting found when I load my plugin from Maya’s plug-in manager:
// Error: file: /library/rez/ext_packages/app_maya/2018.4.7.2/platform-linux/ext/scripts/others/pluginWin.mel line 290: Unable to dynamically load : /net_home/shane.simms/local_packages/testing/0.0.1/platform-
linux/app_maya-2018/plugins/testing.so
libVRaySDKLibrary.so: cannot open shared object file: No such file or directory //
// Error: file: /library/rez/ext_packages/app_maya/2018.4.7.2/platform-linux/ext/scripts/others/pluginWin.mel line 290: libVRaySDKLibrary.so: cannot open shared object file: No such file or directory (testing) //
This only crops up when I use .so libraries (libVRaySDKLibrary.so in this case) - .a libraries don’t give me any error messages.
The following is a simplified CMakeLists.txt, which only has one .so library, which gives me the above error (sorry, can’t upload files from work so have to dump it here):
CMAKE_MINIMUM_REQUIRED(VERSION 3.3)
set(CMAKE_VERBOSE_MAKEFILE ON)
# this is the cmake module used to build maya plugins
include($ENV{DEVKIT_LOCATION}/cmake/pluginEntry.cmake)
include_directories(/net_home/shane.simms/git/testing/include)
include_directories(/net_home/shane.simms/git/testing/vraymaya/texfresnel/)
include_directories(/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/include)
# set project
set(PROJECT_NAME testing)
set(CMAKE_STATIC_LIBRARY_PREFIX "")
# set SOURCE_FILES
set(
SOURCE_FILES
vray/vray_texfresnel/tex_fresnel.cpp
vraymaya/texfresnel/maya_pluginmain.cpp
vraymaya/texfresnel/maya_tex_fresnel.cpp
set(treeparser_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libtreeparser_s.a")
set(plugman_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libplugman_s.a")
set(jpeg_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libjpeg_s.a")
set(partio_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libpartio_s.a")
set(VRaySDKLibrary_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libVRaySDKLibrary.so") # so
set(imagesamplers_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libimagesamplers_s.a")
set(putils_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libputils_s.a")
set(tiff_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libtiff_s.a")
set(bmputils_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libbmputils_s.a")
set(meshes_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libmeshes_s.a")
set(rayserver_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/librayserver_s.a")
set(vrmat_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libvrmat_s.a")
set(alembic_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libalembic_s.a")
set(glvm_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libglvm_s.a")
set(vrscene_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libvrscene_s.a")
set(libpng_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/liblibpng_s.a")
set(meshinfosubdivider_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libmeshinfosubdivider_s.a")
set(osdCPU_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libosdCPU_s.a")
set(pimglib_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libpimglib_s.a")
set(openexr_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libopenexr_s.a")
set(vutils_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libvutils_s.a")
set(geolib_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libgeolib_s.a")
set(pnet_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libpnet_s.a")
set(ptex_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libptex_s.a")
set(curl_s_PATH "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libcurl_s.a")
set(VRAYMAYA_LIB "/library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib")
# add_executable(main vraymaya/texfresnel/maya_pluginmain.cpp)
# target_link_libraries(main /library/rez/ext_packages/vray_maya/4.12.01.29159.0/platform-linux/app_maya-2018/vray/lib/libplugman_s.a)
set(
LIB_DIRS
${VRAYMAYA_LIB}
# Load libraries
link_directories(${LIB_DIRS})
# set required libraries
set(
LIBRARIES
OpenMaya
Foundation
treeparser_s
plugman_s
resman_s
jpeg_s
partio_s
VRaySDKLibrary # so
imagesamplers_s
putils_s
tiff_s
bmputils_s
meshes_s
rayserver_s
vrmat_s
alembic_s
glvm_s
vrscene_s
libpng_s
osdCPU_s
pimglib_s
openexr_s
vutils_s
geolib_s
pnet_s
ptex_s
curl_s
# Build the plugin
build_plugin()
# install the plugins
install(
TARGETS
testing
DESTINATION
plugins
install(
FILES
shaders/vraytexfresnel.txt
DESTINATION
shaders
# rez-2.18 onwards doesn't provide a default install target
# we have to provide a phony one
install(CODE "")
Any advice on this would be hugely appreciated, please let me know if there are any details I missed out.
