attached a screenshot of the GPU usage during a progressive GPU rendering of a complex model at 12000x2000. It looks like approx. 50% of the GPU power are unused. This is only one of the both GTX2080ti, at the second it looks better.
New test - I started a GPU bucket rendering and it looks much better - see second screenshot. The render time is halfen. Is this normal? Is it because a bottleneck of my machine? I use a DualXeon E5-2687w0. I plan to upgrade to a Ryzen 3950x - will it be better there?
Kindly note that this is reproducible in V-Ray 4.00.02, however, it has been resolved in our internal builds and GPU performance will be utilized fully in the next release (whether it is a stable nightly or an official build)
I’m not sure it should be fixed yet. At the last nightly sill a lot of GPU power is unused. (I wondered that my cards are so silent and the fan not full blowing.)
Does this occur with a complex and/or rather simple project?
In the meantime, could you try rendering with the VFB disabled and see if this resolves the issue? To do so, please use the following script provided by my colleague in another forum thread:
I tested the script and disabled VFB - full speed is available. I hope this is a test only and on the long run the full power will be available for VFB use too.
