Soften raytraced artificial lights shadows
Status: declined
It would be great to be able to soften artificial light shadows in the same way as natural light shadows.
Submitted on AHA Ideas by Steeve Jomaa (ENSCAPE-I-1655).
But softening shadows from natural light is only possible because the sun’s properties change throughout the day. Artificial light doesn’t have this property; artificial light is unique and can’t be altered except by the properties of an IES light. It doesn’t make much sense.
Submitted on AHA Ideas by Raphael Fernandes.
@guest Would you please elaborate when do you need this? Maybe with some screenshots?
Submitted on AHA Ideas.
Enscape already uses hundreds of approximations and hacks when it comes to lighting, artificial or otherwise.
Calling for scientific accuracy in rendering software that is not physically realistic is a bit ridiculous. It’s not Maxwell Render, after all.
The idea is to avoid time-consuming tinkering in order to obtain smooth images and realistic lighting.
The shadows generated by non-IES artificial light sources are WAY too sharp and clear. Basically.
Being able to soften artificial lighting would greatly simplify the workflow.
Using IES systematically for all light sources is completely impossible on some projects.
And absolutely unnecessary.
I am requesting this feature because it exists in most 3D rendering software.
There are very few light source settings, and having more options would be beneficial.
Submitted on AHA Ideas by Steeve Jomaa.
The shadows generated by non-IES artificial light sources are WAY too sharp.
Sometimes you need to add some soft artificial light. And you just cant.
Because even a low power light will generate a sharp and hard shadow
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
