Solar Angle/Time of Day not saving in the view. Angle changing in saved views
The solar angle/Time of day is not saved in the view or the visual preset settings. This is essential because I need this to change between views I am using in the same project.
Also something I have never had before, is the angle or perspective changing in a saved view when I haven’t changed it… this completely ruins my workflow because I need the views to align when loading them into Photoshop or InDesign. I haven’t moved the angle in Revit, Enscape or changed the field of view etc?
Currently very frustrating as I am having to re-setup the views every single day and they still wont perfectly align with previous versions!
Have you changed the perspective between cameras? It looks like the left is set to Two-Point and the right to Perspective. Enscape will keep your latest setting without moving camera position/location.
Some insight here from another thread. :slight_smile:
The time of day and date is set / saved in the Revit view properties and can be recalled by Enscape. Here’s the step-by-step. https://www.linkedin.com/pulse/creating-solar-studies-revit-enscape-phil-read/
