1. where do i find hair/strand settings in solaris?
2. width give 2x to thick strand in vray solaris compared to old vray and karma
V-Ray for Houdini number:19358 hash:b65e856 from 17 Jan 2022 03:26 (build number:19358)
V-Ray Core 5.20.20 [98c908c8] from 21 Dec 2021
houdini 19.0.455
linux centos7
hair_width.zip (54.2 KB)
hello again!
hair width is correct now, thanks!
@Gosho.Genchev and I talked a bit aboutthe hair settings and i wanted to feedback on them to see what you guys think
1. *width mult* - seems totally unecessary
2. *tesselation* - gosho said something about settings these things in usd instead. would you mind showing a noob like me
3. *min. pixel width* - we use this one so it would be nice to have it in the render geometry settings under the hair tab maybe
3. *render as smooth curves* - same as 2
4. *width in pixels* - we dont use this one but could go under the vray/tab
5. *generate W coord* - guess we dont need this anymore? dont think we use this one
Regards Alexis
All of those options are already in the Hair tab of the render geometry settings. As usual you have to recreate the node after new options are added to the ui (the way Solaris works… may be there is force update of the UI but I’m not aware of it).
@bdancer cool! Sorry that i missed that one!
continuing this thread a bit about curves and hair.
Right now the hair tab doesnt seem to do anything and vray doesnt seem to know how to read interpolated curves. So right now there is no way to do it that i can find.
Im uploading some examples that would be nice to get working
karma vray
another issue is also that vray seems ro render the strands from hairgen longer. I included an example in the hip file
karma vray
V-Ray for Houdini number:19508 hash:babd98a from 20 Jan 2022 16:06 (build number:19508)
V-Ray Core 5.20.20 [4c3e2fea] from 17 Jan 2022
houdini 19.0.455
linux centos7
hair_curves.zip (97.5 KB)
The width multiplier is not in the hair tab any more, what is the current way of multiplying it? Thanks!
@glacierise I can see the width multiplier in the hair tab on render geometry settings. Though i recommend to use as much usd as possible. If you instead change the @width attribute you get the correct thickness in karma and vray. Ill attach an image below.
Hah yes thanks, I’m still in a bit of a packed disk primitive mode, afraid to touch these geometry attributes at render time
Will do the attribute route, thanks!
Though weirdly, I updated vray to a recent build, 22410 from May 19 2023, and I still don’t see it. Nevermind, will go the attribute route.
EDIT: Hm, checked that - modifying that attribute actually does cause the USD layer to save the widths, making the file bigger. Yes it’s not time sampled, but still… Would be great to have the render geometry property working.
hehe yeah, i would encourage it though its very cool to be able to access everything all the time in usd which will open up alot of possibilities
About the width mult ill attach an image below to see we are talking about the same thing. Im on 19.5 and latest nightly. In solaris the parameter dont get force updated like in legacy so you need to dropdown a new render geometry settings to get new parameters.
Yes that place - looks still like this to me:
1. Well, you have to update I guess…
2. Are you looking at the existing node or created a new one? Solaris never updates UI automatically - you have to recreate the node if any settings were changed.
New one. Weird, build is from only two weeks ago.
