Solaris Temple Renders
Hey guys, just an environment piece based on the Eternal Laboratory from Path of Exile. Modeled in Max+Zbrush. =] Renders were between 4-7 hours each, PT+UHD
The renders and rest of my exhibit are also available on my site, www.zach-schwartz.com
Woha, love this! Would be cool to play serious sam in level like this :]
Glad you like it romullus. :} Can’t say that I’ve played Serious sam before though.
These are awesome. Congrats, great looking work!
Just beautiful.-
Great unusial work.
This would be a mighty and atmospheric animation :- ).
(too expensive to render :- / … )
I belive that something could be optimised for animation to get some speed improvements and if it will not be 4k but 1080p then it will be already 4 times rendertime drop
Many thanks guys. =]
@Juraj_Talcik, Nekrobul
Yea in its current state the rendering would be too expensive for a decently long/short animation. However it’s true as Nekro says that it could be optimized; for one the albedo isn’t optimized (I noticed a bit late & just decided to wait out the renders since I plan on doing a part 2). In particular, I noticed red blotches in the albedo pass for most of the white marble in the scene. Apart from that there may be other optimizations including single-bouncing the fog volume or taking a less costly approach. Either way I planned on a possible short (lower res) animation for the middle ring-console spinning — as it does in the game.
For hardware, I rendered with a single 3930k
Actualy it is very good times for this procesor. I am using this one myself. And i am geting mostly 35-50k samples/s.
I saw the pictures and thought Path of Exile! Then I read the title and description.
Great work, Lady Dialla would be proud.
Yea for the most part I find the render times to be great; plus with low thread priority I can multitask while doing test renders. I would like to see what results I’d get with a couple optimizations (primarily albedo) though.
P.S Great renders on your arch viz/studio website. Nice work.
Aha, pretty cool that you recognized it. ;}
Thanks dub.
Nice Job!
