It seems to have been broken in the latest v-ray build (3.20.01). Can anyone verify?
yep!!! its broke!
Okay, thanks for confirming.
Hm, I don’t think we actually did any breaking changes… is there any error message?
The ‘SolidRocks is starting…’ just sits there and never starts.
Ok, then it would be best to contact the developers. I’m comparing the parameters and we haven’t made any booleans into integers this time, so not sure where this comes from.
I have, but I haven’t heard back. Thanks.
Have you heard anything? Would be interested in hearing how it works with 3.2. I looked on Solidrocks forum, but it doesn’t seem he answers peoples questions much.
He said to check the site at the end of the week.
He used to be really responsive, but yes lately, not so much. However, after a couple days, he did answer my email.
Such a great program!
Would be cool if he had it setup for VRay RT rendering and Vray RT production rendering. I heard its only good for Vray adv
in the case of Vray RT, i cant see the point of solidrocks at all. there are very few settings, and you just leave it going until your image looks nice. hardly needs a setup assistant.
To be honest when ive tried solidrocks, ive found the interface more confusing than the normal vray one. Plus it changes literally every setting in vray, so going in to edit/fine tune what its done, is fiddly to say the least.
now we have the progressive sampler, and a handful of “set and forget” configs for vray that leave you with only 2 or 3 parameters to adjust, it just seems a bit.. well, lets just say its not for me.
Actually, I can’t beat the exterior presets. Exterior default eats through my exteriors in 20 minutes at 4k. This is with displacement, grass, and a ton of trees. I have tried every combination of V-Ray’s Quick Settings and the fastest I can get for the same project is a couple hours. For interiors, not so much. I can’t get a clean rendering, even with everything at its max in SR.
Hm, do you think you can get us a scene like that? Definitely want to make this go faster.
I can; maybe when he updates it I’ll post my current exterior.
Hello !
thanks for discuss around SR ;). As i said to Glorybound by email, i do my best to make a release asap !
and yes, since 3 months i’m a bit overloaded because of a beautiful, superb, awesome little boy in the house.
So, sometimes i just can’t answer within 24h.. trying to sleep somewhere ![]()
I’m polishing the 1.8 build (compatible with Vray 3.2 and max2016)
if i remember well nothing special, except that vray version check, wich was locked for anti hack and because i really don’t know each time what will happens for the next round.
I prefer that SR crashes at starting instead of having unpredictible results.
i’m pretty happy of the incoming presets, bit faster than 1.7 (less AA, more DMC) and seems well balanced.
Still working on new version alert stuff, some gamma debug as well.
made at this moment for 1.8
- ok for Vray 3.2
- ok for max 2016
- Srgb button now managed automatically
- better glossy subdivs computation algorithm. Now it depends of relf glossiness value AND id ponderated with requested quality (medium, good…)
- Debug : added some “animate off” commands to avoid some unwanted keyframes on light subdivs when using anim wizards
- SR is now in good mode by default.
- Proba lights is now OFF by default.
- New “No GI” method ! i finally pushed my students for some complex exterior animation scenes (tons of luminous crystals and insects in a dark forest with everything animated…sic) to have a test ride with No GI, only dome+Vrayambientlight. (and far away spherelight as sun if needed). Dome alone gives lot of grain, but combined with Vrayambientlight gives pretty nice results : clean render (more contrasted) than Gi, flicker free of course, super fast rendering… so impressive that i decided to include this mode into SR. Thanks Chaosgroup for this VrayAmbientlight ! My students often prefer this result than the GI one for exterior anim rendering.
not sure for a setup tomorrow, i’ll do my best. I’ll skip some user requests at this stage to make a working version with 3.2 asap !
Awesome and thanks!
