SolidWorks/Sketchup Render Effect?
Does anyone know if there is a way to render an object to look like this? Essentially a flat-ish colour with a black outline only on the edge. Thank you! P.S. I’m using 3ds Max
If you need flat color why are you using corona? Scanline + ink shader can render this
Currently not possible without some heavy hacks. (falloff map?)
You can vote for the toon shader in our “most wanted” poll: https://forum.corona-renderer.com/ The most wanted feature?
