Is there not a way to solo a node to the surface in v-ray like you can with Arnold and Redshift? I.e. you have a node material and just want to see the effect of the curvature node, can I not output this to the surface bypassing the main shader?
Hello @shane_mckenzie ,
Adding support for the “Solo” mode in the node editor is on our to-do list (request ID: VC4D-1000) and will be implemented in the future. I will let you know once we have updates on the matter. Thank you.
As I already mentioned here, with the release of V-Ray for Cinema4D, Update 2, we now have added support for the “Solo” mode in the Node editor! You can download the latest builds from here. Thanks.
