[solved] alpha help! (white fringes around trees)
Hi there
I hope you can help me. I’m losing the plot here!!!
I have rendered an image out as .EXR and loaded it into Afinity photo.
Then, I used the alpha channel pass to remove the sky from the beauty. All good.
When I drop a background in behind I still get the white lines around the trees.
How can I fix this?? Is my alpha set up wrong?
Is this a corona thing or an PS/ Affinity thing??
cheers
Neal
Have you tried using the ‘Direct Visibility Override’ in the scene settings? If you override it to black you should get a better Alpha channel.
That’s what worked for me as I was having the same issue as you.
Thanks for reply I tried that and it fixed the issue. Thanks
Try to render selected objects only in exr-File, this schould make a perfect mask.
pleae look at the example pictures.
on the right hand you can see how i comped them.
Please support me to convince Ondra to take selected object render pass in render Elements it would save many comp time and money.
