I have some issue with backburner network rendering. On few my render nodes I get correct renders, but few of them render correct but save black RGB chanel.
I chose .hdr output file format to save.
Hi, sorry, but we cannot help you with as old Corona versions as 5. It was released in 2019 and is currently 3 (almost 4) versions back.
It may be some general Max / BB problem. I would advise:
removing all render elements and adding them again
making sure your file output settings are correct (e.g. saving with 32-bit full float option, not half-float - there were some issues with this in the past)
making sure on all computers you have exactly the same software and same versions (e.g. all plugins)
You can also try opening and rendering the scene locally in 3ds Max on the render nodes where it is failing and checking if there are some error messages.
