hi
The problem is,
I launch multiples render via backburner and i only use the noise limit to stop the render.
But when the limit was reach, the render restart again, finished and restart again until he reached the default limit render of backburner (600 min)
I Dont know if it’sa problem from max or from corona.
Do we need to specify a time (99:99:99) limit and passes (9999) ?
Sorry i make another test and No it dont work. After the pass limit reached or the time limit or the noise level, the
render closed, and save.
In the monitor the render become red in waiting mode and after the job completely stop, he restarting it.
It doenst happen just by with max.
i sending the job by saving a tif or jpg ( png doesnt work…png library error). 5k render output. noise level to 7%. everything in default. No DR used. Some render elements ( Ao, wirecolor, refl, Z)
in the errors tab from the monitor i have this:
3dsmax adapter error : Autodes 19.2 reported error : Could not read/write file tytpe: \......\GRANITE.CEL
don’t know what is that ! It’s from a 3d asset from 3dsky.org
don t know if it’s a texture.
i will tcheck that
ok it’s works now.
i deleted these strange file.
it was like a missing file (using relink bitmap) but don’t know this extension. simply erase it.
don t know why back burner render the frame and save it correctly and try after to read write the missing file
thank for the help.
Hello, sorry for interrupting this thread but I would like to ask how you use backburner to render single frame on your slave? I have no experience with backburner whatsoever but it would be very valuable for me to know, as I havent found any specific thread on this topic on the forum. As maru asked, could you maybe do some 1 2 3 step “tutorial”?? thanks!
