Dear Chaotics,
yesterday [all my troubles seemed so far away] I was browsing Cosmos and I found a perfect plywood materials that I was looking for (see attachments). I downloaded the asset but Max seemed to be frozen so I did a forced shutdown of Max.
When I opened Cosmos again three of five plywood assets were not there anymore. I checked on my folder and I actually downloaded the 50cm plywood texture but now I can not see it on Cosmos. I updated to Corona 10 to check if that was the problem but it is the same. What can I do?
Hi, if I open Cosmos from the V-Ray toolbar, I can see 5 plywood assets (same as in your screenshot). If I open Cosmos from the Corona toolbar, I can only see 2. Please note that such differences are expected as some assets may not be converted to Corona yet.
Is it possible that you originally opened the V-Ray Cosmos and downloaded the V-Ray assets?
Dear Maru, thank you for your answer. It is totally impossible because even if I have vray (just to be able to convert to corona) I never use it and I don’t have the toolbar on.
So, maybe, for some improbable reason max/corona opened the wrong library. That was useful to me because I discovered other textures. I think that Chaos team should include some assets even if not perfectly compatible.
One can convert after and it’s ok. Maru, your suggestion drove me to solve this problem. Thank you.
