I have found a strange, presumably bug while trying out product animations. This relates to both saving from 3DS MAX’s save file dialog and saving straight from the Corona VFB.
If a merged AOV exr is saved then there is very clear color banding and loss of information in the 32 bit exr file (very visible in depth pass). If all AOV’s are saved separately and not merged, then the banding issue disappears. I also tried two different exr extractors (exr.io and after effects native EXtractoR). Both times the same issue, which would suggest the problem lying in the file saving. Is there some limitation on merged exrs that causes this issue or is this a corona related bug?
See attachments & kind regards,
Arnaud
