Since the Corona update (V6), when i open 3DS Max 2017, all digits have comma separators. Whereas before it was dots.
It is therefore impossible to enter numbers with the numeric keypad, even when changing the Windows settings.
The only odd way I have found to solve the problem is to run a render, even an empty one, stop it, and run any Maxscript application. And after this, the numbers find the dot as a separator.
Strange, isn’t it ?
I specify that I also have a 2014 version, and that there is no problem with this one.
How to avoid doing this manipulation each time 3DS is started ?
I had already tried to change Windows settings. But without results. So I returned to the original setting which is the dot.
Funny thing: after doing the manipulations described in my previous message, I have all 3DS max that works with dots as a separator except Corona’s VFB which keeps the comma.
