[solved] Corona + 3DS Max: How to save Render to Texture images?
I’m trying to use Render to Texture in 3DS Max to bake the lighting onto objects in my scene. Everything’s working fine, except it doesn’t save the images into the folder. I’ve tested with all the same settings using Scanline Renderer and those save out perfectly.
I’ve tried searching around for a solution to no avail, is this a known issue and what can I do to correct it?
Any help is appreciated,
Which version do you use? There has been a (https://forum.corona-renderer.com/ RTT baked maps don't get saved anywhere ) in Corona versions < 2 (Fixed in v2 / DB2018-04-26): No bake images were saved if “Elements Active” was not ticked in the “Render Elements” tab.
Good Luck
Apologies, I’ve figured out my issue! When I was selecting the render elements I was selecting the basic 3DS Max Elements instead of scrolling down and applying Corona’s own elements
Thanks for the help anyway!
