Hello to everyone,
When I received an interactive render in the old version of Corona, I was getting a clear image. I switched to Corona 5, and tested the interactive renders. I have a problem with Corona 5 or I have another problem. interactive render this way smoky
Does anyone know the solution?
I found that the problem is related to this tab. Force path is improved when you choose tracing but there is no sharpening like before
I think the problem is related to the use of Nvidia denoiser in IR. Try to uncheck it, and see if it helps. This should make IR works as in previous versions.
Please see this guide:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000053263
thank you everyone
Hi everyone
I know this is an old topic…
This option of the interactive render in the settings of Corona 12 is no longer available. Is there another solution to remove this blur during IR ?
Thanks !
Roland
Hi, please see this article listing two ways to fix “blurriness / pixelation” in Corona:
https://support.chaos.com/hc/en-us/articles/4528474828177-Rendering-has-low-quality-looks-blurry-pixelated
Thanks a lot !
