[Solved] CoronaCamera Tilt&Shift different behaviour/scale from max2004 to 2005
Hi, I can’t figure out how to fix this: in Max 2024 a single click on the camera shift is equivalent to a minimal movement, while in Max 2025 the movement is ten times larger in scale, can you help me? I attach examples.
This happens using all spinners? If so, then check spinner settings:
“Preferences” → “Spinners” → “Snap”, especially “Use Snap” checkbox
Good Luck
thanks that was exactly it !!!
