I have upgraded my setup from Ryzen 3900x to TR3960x (which in Corona benchmark is around two times better), and quite fast I have noticed repeating issue.
I run Windows 11 with max 2024 and Corona 10 hotfix 1.
My CPU usage vary on the currently used shader. I am talking about both, interactive and production renders. I usually use Corona Physical Material and I of course use some legacy, but converted, shaders with Corona Bitmaps. This problem appears between two Physical Materials in this case, but it also occurs with legacy ones.
I attach the screenshots of the shaders. Those are not very complex ones, those are fabrics, but usually with the displacement. On trail and error I have found that removing displacement solves the CPU usage clamp, and it goes up to 100%, with only displacement plugged in - same results, usage clamped.
Shader number 1. has the lowest displacement value in size, and renders with 100% CPU usage. Shader number 2 and 3 have more intense displacement and goes respectively 50% and 65% CPU usage on both interactive and production. I Do use 2 or 3 px displacement resolution in scene settings.
Is this case a known way the renderer works, or am I missing something?
There is a bug in Corona 10 where triplanar maps can cause significant slowdown. This has been fixed and the hotfix should be released very soon.
It seems like you are using triplanar textures in your shaders and recently, there were some reports about performance drop when using triplanar textures in Corona. The fix is already present in Corona 11 DB which you can try it and see if it solves your issue.
You can download Corona 11 DB from here: https://forum.corona-renderer.com/ Chaos Corona 11 for 3ds Max - Daily Builds Changelog
Note: The daily builds are the newest, experimental versions of Corona Renderer intended mainly for testing purposes and to showcase the recently added features. They contain the latest bug fixes but are not guaranteed to be stable, and in some cases can even damage scene files.
Check this link to know more about it: https://support.chaos.com/hc/en-us/articles/4528206493329-Corona-for-3ds-Max-Daily-Builds-
thanks guys for suggestions. Just curious if I can handle both versions of Corona at the same time? Use 11DB in problematic scene and 10 in others?
BTW the hotfix for Corona 10 that addresses the Triplanar slowdown is now out:
https://forum.corona-renderer.com/ Corona 10 (Hotfix 2) released for Cinema 4D and 3ds Max
(so you won’t have to use a daily build to access that fix any more
I haven’t known that you have started “hotfix on demand” feature xD Thanks!
edit after update :
yeah this resolved the issue.
