[solved] Crash after starting render, Crashed Module Name: Corona_Release.dll
I didn’t have this issue before, I have been using Windows 11 since the first time Ive been using corona and 3dsmax. Please help me :frowning:
Date/Time: 2024-04-14 22:07:08 +03:00
Application: 3dsmax.exe
Error: Access violation - code c0000005 (first/second chance not available)
Exception Address: 0x00007ffcfff1bdd3
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, ffffffffffffffff
3dsmax_minidump.dmp (9.39 MB)
Hello, what version of Max and Corona are you using?
I believe this issue has been solved here: https://forum.corona-renderer.com/ 3dsmax crashes after starting render. Crashed Module Name: Corona_Release.dll #msg223741
3ds max 2024 26.0.0.940, Corona 10 Hotfix 2.
Yes, the problem was in BIOS settings.
What’s the solution?
What’s the problem with the BIOS?
The link isn’t working, I can’t see the solution.
